1970'S FORD 4500 SKIP LOADER HOW TO BLEED FUEL SYSTEM?
   / 1970'S FORD 4500 SKIP LOADER HOW TO BLEED FUEL SYSTEM? #1
tytrucks
eNCINITAS,CA
FORD 4500
We have fuel all the way up to the injector pump. When cranking it the bleeder valve on the bottom of the pump sparays out. But when cracking the injectors individually we are not getting any diesel to what we believe is the #1 injector . What's the proper procedure to bleed the system?
   / 1970'S FORD 4500 SKIP LOADER HOW TO BLEED FUEL SYSTEM? #2
Proper or not, once I have fuel to the injection pump I crack the line fittings at the pump to ensure output. If you wish just do them one at a time from one end of the pump to the other. To me the order is less important than ensuring output. Having done that and tightening the fittings, move to the injectors and crack the fitting at one injector and crank until you have clear fuel flow. Do the same for each injector and you should be good to go.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2005 Freightliner Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Freightliner...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2015 Chevrolet Express Shuttle Bus (A50323)
2015 Chevrolet...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
Deere 302K (A50120)
Deere 302K (A50120)
