1971 Gravely Commercial 450 Transmission-PTO
   / 1971 Gravely Commercial 450 Transmission-PTO #1
slappy
I have a 1971 Gravely 450 Commercial Lawn and Garden Tactor. I have been experiencing problems related to the transmission and PTO. Initially I began to have problems with the tractor maintaining its ground speed in the 2nd Gear-High range. The tractor seemed to "surge" into gear and go fast but then would do the opposite and slow down and at times barely move. I adjusted the jam nuts on the transmission shift lever linkage per the manual and this seemed to help for awhile, but then it started to have similar symptoms once again. I have been thinking that I need a transmission rebuild. I called one of the Gravely dealers and they indicated there are a couple of clutch plates in the transmission that could be worn. I have a parts diagram of the transmission but don't see any clutch plates listed. Can anyone familiar with this type of unit tell me what the normal "wear" parts would be that need replacing? Or have any comments or suggestions for repair? Problem # 2 relates to the PTO. When the PTO is engaged to the mower deck it sporadically makes a clanking-grinding noise and the PTO lever vibrates and almost wants to jump out of the IN position. I opened up the PTO and found the thrust bearing in 2 pieces and am assuming this is the problem. If I replace the thrust bearing should this correct the problem or perhaps this is a symptom of other problems?
   / 1971 Gravely Commercial 450 Transmission-PTO #2
Not sure if this is like the Gravely walk-behind xmissions, but those have a big conical clutch "cup" that is what wears.
I think you've got it right on the thrust bearing for the PTO. The engagement "dog" won't engage fully if the thrust bearing is not there to push against. It can then jump out of engagement and vibrate like you are seeing.
You can also try calling Richard's Gravely in WV (304-927-4580). They are experts in all things Gravely, new and old, and are usually willing to talk through tech issues on the phone, particularly if you buy a few parts from 'em!
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2021 Chevrolet Corvette Stingray C8 LT1 Convertible (A51694)
2021 Chevrolet...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
