1972 Ford 4000 3-Cyl Gas, Various Problem
   / 1972 Ford 4000 3-Cyl Gas, Various Problem #1
newtraditionsfarm
Beaverville, IL
Ford 4000 1972 3-cyl Gas
I have 1972 Ford 4000 3-Cyl gas with a cooling problem. I flushed the radiator, which seems to have decent flow (thought it's pretty old and some of the fins are bent). The tractor starts up fine, usually blows one puff of white smoke until it gets going and then the exhaust is clear. After about 600' running my 4' roto-tiller or two bottom plow I start boiling over and loosing coolant. I've replaced the thermostat, radiator cap and radiator hoses.
Is it worth replacing the radiator and water pump? When I run the tractor without the radiator cap I see slight ripples in the top of the radiator. Does this indicate full flow? How rapidly should the water be moving? Also, so far I haven't seen any bubbles in the coolant. Which I'm hoping is a good sign.
Also, I have a serious issue with pressure in my gas tank. After about 3-4 hours of running the tractor, pressure builds up in my gas tank and it starts to act like it's out of gas. I replaced the gas cap with a replacement from Napa, which claims to be vented, but there's no difference. Any ideas?
   / 1972 Ford 4000 3-Cyl Gas, Various Problem #2
is this a cross post? semms like i've read and replied to this somewhere else?
   / 1972 Ford 4000 3-Cyl Gas, Various Problem #4
ok, that makes 2 other places I saw it then. :)
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
