1972 International Harvestor 140 Air cleaner / Filter replacement
   / 1972 International Harvestor 140 Air cleaner / Filter replacement #1
superstevek1
Thurman, NY
None looking
Hello does anyone know who makes a replacement air filter / air cleaner for this tractor. It was sold as an entire assembly back in the day. Does anyone know what works as a replacement cleaner today. Thanks
   / 1972 International Harvestor 140 Air cleaner / Filter replacement #2
Isn't that an oil bath breather..?? Just remove the cup from the bottom, dump oil clean, refill with the same oil used in the engine. If you're meaning the mesh filter above the cup, remove filter housing, and wash with a solvent of choice, dry and put back on. Unless it is rusted out, cleaning it is all that is necessary, and should last a life time.
Yes it is a oil bath cleaner. Yes, I was meaning the mesh filter in the top of the canister. Ok I will try to remove it and clean it and put it back in. Thank you.
   / 1972 International Harvestor 140 Air cleaner / Filter replacement #4
I don't believe it is possible to remove, pretty sure it's permanantly affixed in there. You need to submerse the whole filter housing in something like a bucket of diesel fuel, or water based degreasers like simple green, purple power, or something similar.
I use diesel fuel, but the I can burn that in my waste oil furnace, unless I'mdoing a complete tractor tear down, and use it as a parts cleaning solvent. Use what would work best for you.
OK! That makes sense no wonder I cannot get it out! Thanks again for the follow up will pick up a few gallons of diesel
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55218)
2016 Ford F550 4x4...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
