Jake.P1028
- Joined
- Aug 30, 2021
- Messages
- 2
- Tractor
- 1976 Ford 1600 2wd 2cyl 1.3l Diesel
thank you for having me, this is my first post here - I recently purchased a running driving ford 1600, attached was a 770Loader [?] and a Bradco 7ld Backhoe - Upon investigation i noticed the backhoe has its own hydraulic fluid reservoir, and upon inspecting fluid noticed it to be milky- i know this is a sign of water\moister in the fluid - and understand a drain, flush, refill is in order. my Question is whats the best fluid, and whats the capacity? I can post pictures if nec, the res. does not have a Dipstick, but does have 2 plugs on the side of the tank, one lower than the other but neither are on the bottom bottom, so a fluid sucker to pull it out, but then comes the refilling - with no dipstick would i just top the res all the way to the breather? - TIA .
