1978 Case 580C power shuttle forward clutch piston
   / 1978 Case 580C power shuttle forward clutch piston #1
ewbaxter
Penn Yan, NY
Case 580C
Hi Folks,
Here is a newbie question. I am doing a rebuild on a 1978 Case 580C shuttle transmission due to slipping/not moving in forward. I have the service manual and have been following the disassembly steps. Everything was going fine right up to the point where I am supposed to remove the forward clutch cylinder and piston assembly from the ring gear. I have removed the retaining ring but I can't seem to get the cylinder out of the ring gear. The manual says this is a light press fit but I can't seem to press or drive the cylinder out. I am trying to be careful since a new ring gear isn't cheap. I have tried to drive the cylinder out from the bottom (the side opposite the clutch spring). Am I missing some key trick? Thanks for any help you might have.
Eric
   / 1978 Case 580C power shuttle forward clutch piston #2
Is it possible to try a little heat or dry ice, as appropriate?
Hi Bob,
I will try the dry ice, I was a little hesitant to use heat, replacing the ring gear is an 800 dollar proposition.
Thanks,
Eric
Toro Sand Pro (A56859)
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2373 (A60432)
2373 (A60432)
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
