1981 Mack Fire Pumper ... Brakes
   / 1981 Mack Fire Pumper ... Brakes #1
tc35dforme
Platinum Member
New England...Central MA
TC35D/16LA
Okay guys,
Once again I turn to the collection of knowledge known as TBN.
When I'm not attempting to work or doing the TBN thing, I serve as a Lieut. on our local fire department. We are currently considering purchasing a used fire pumper to serve as our reserve truck.
The unit is a 1981 Mack EM6-285. One of our committee members has expressed concern with it possibly having 'Kelsey-Hayes' brakes.
I freely admit to being a big truck idiot...
Is there any concern with Kelsey Hayes brakes ? Have any of you guys had any experience with them ? Thoughts or Comments.
   / 1981 Mack Fire Pumper ... Brakes #2
I can't imagine that being a problem. No doubt it has air brakes. Parts for medium and heavy trucks are available for much longer than pass car/light truck. Kelsey Hayes was bought a couple of times since then, now I believe it is Hayes/Lemerz. I wouldn't let this affect your purchase /forums/images/graemlins/smile.gif
   / 1981 Mack Fire Pumper ... Brakes #3
I'm thinking back when I owned my truck-tractors and it seems to me that 80 - 84 or so model year trucks with Kelsey-Hayes brake systems (not necessarily restricted to Mack) were very problematic. This was due to that overnight vote of congress that trucks had to have anti-lock brake systems. These systems were designed literally over night or so it seemed. Along 85 -86 or so the bugs were worked out. 99% of the problem was electronic sensors which triggered brakes when not needed or didn't trigger them at all. The last large car that I bought was an 89 Navistar and it was problem free by this time. Memory is off some, I admit, haven't been in a rig since January of 91.
lamarbur,
I spoke to the mechanic who works on the truck and he said that the ABS system has been disconnected and/or bypassed somehow. I believe it was a factory callback thing ?? early on.
Thanks for the input.
   / 1981 Mack Fire Pumper ... Brakes #5
I would say about all trucks from the late 70's and early 80's with antilock brakes have been disconnected and changed over to regular air brake valves which is ok and safe. Most trucks have Eaton or Rockwell (Meritor) "cam" foundation brakes at the wheels. This truck with Kelsey Hayes should be air over hydraulic disc brakes on the front and standard "cam" air brakes on the rear drive axle. It could also have full air disc brakes on the front (again Kelsey Hayes). The air over hydraulic is much more complicated and the parts are available but expensive. The calipres are difficult to work on. Disc brakes on trucks do not last as long and are alot more expensive than "cam" brakes and do not stop as well. None of the fire departments we work for have trucks with the KH brakes any more. They were ok until you had to work on them and repairs are costly. The KH brakes should be on the front only and most likely Rockwell on the rear (cam).
   / 1981 Mack Fire Pumper ... Brakes #6
The fire department I work for ran Macks of various vintages for many years. I'm not sure what brand of brakes they used but they all had full air with drums all around. As far as I know we never had any major problems. Some of our older Macks (pre-1974) had a "front brake limit switch" which was supposed to prevent front wheel lockup by limiting the amount of air sent to the front brakes. Those were eventually outlawed and I doubt the '81 Mack has one. The 285 Maxidyne is a strong, reliable and economical engine. Our department has three Macks for sale, an '80 and two '84's, let me know if you are interested.
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
1273 (A50490)
1273 (A50490)
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
