1982 Ford 1100 rear rim size
   / 1982 Ford 1100 rear rim size #1
BOJO
Bristol, PA
Ford 1100
I need help replacing or repairing a rear rim, I can get the numbers on the side 16 x 5 JA but all the rims I find have a 6'' hub dia mine is 3.5. The rim is spidering with crack off each bolt hole. I would really like to replace it. Tractor came with a house my father in law purchased. It has a brush hog, a blade and a Woods box scrapper. and the new motor has about 100 hrs on it. I have used it for the past 2 years and love it. Now it is time to put some money into it. Ordered a new alt and bracket conversion to single wire alt. the battery was no charging because the alt went bad
I would love to find a set of arg tires and rims for it, it is 2x wheel drive and does get stuck some time with the turf tires. It is mostly used in the woods now hauling fire wood and clearing the paths.
Any help would be greatly appreciated
Thank s Brian
TORO Z MASTER ZERO TURN MOWER (A51247)
TORO Z MASTER ZERO...
1837 (A51248)
1837 (A51248)
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
New Holland TN65S (A50123)
New Holland TN65S...
