1983 Ford Ranger Diesel
   / 1983 Ford Ranger Diesel #11
What a great find!!!
Toyo Kogo, which is part of Mazda Corporation got the rights from Perkins to build a engine for Perkins. It is a true diesel engine. The best diesel engine put in a compact pickup period!
It is a naturaly asperated, overhead valve, dry sleaved, gear driven valvetrain, indereck injected, diesel. The engine holds almost 8 quarts of oil. It has 2 oil filters. 1 fullflow and 1 bypass. and it came equiped with a external oil cooler.
Use Napa oil filters. and I would save your money and use dino oil. I prefer Shell Rotella 15w-40.
I had 2 of them! I sold 1 with over 375,000 miles and kept my personal one. My personal one had a rough life.
I beat the #$@&%* out of it for over 513,000 miles.
Engine govener pegged the whole way on the New Jersey Tpk. for 4 1/2 years 5 days a week before I went through my 3rd input shaft bearing in the trans. and got tired driving it. so I sold it to a friend for $500.00 and he drove it for around another 60,000 miles. before he spun a rod bearing not warming it up in sub zero temp. so we rebuilt the engine.from an engine we found in a bone yard. the crank is hardened so we used the crank and 1 rod in the other engine. Threw in new mains and rod bearings. gasket set and new rings.
One note I must let you know when we pulled the head off the cylinders still had honing cross marks so we just honed it so the rings had something to seat on. then he drove it for aprox. 9 months months untill it could not be inspected any more.
He sold it to a person for $600.00 that exports them to Equadore.
It was the best truck I have ever had period! And I wish I could buy another new one.
My advise is like I said use dino 15w-40 oil and change both filters and oil at 3500 miles. because the engine will outlast the truck.
Oh and they love being run hard!!!(keep the RPM's up at around 2000-3000 city driving and highway 3500 is not to fast). Just don't baby it.
The only times I had seen a failure on this specific engine is not letting it warm up before taking off or lugging the engine.
   / 1983 Ford Ranger Diesel #12
<font color="blue"> "sell it before it bites you. ex ford dealer" </font>
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
I've been looking for a Ranger diesel in decent shape for several years. After 20 years, they don't look too pretty anymore, but they run forever. The other American cars and trucks I've owned with Japanese diesel engines fared quite well too, and I regret ever selling them.
</font><font color="blue" class="small">( sell it before it bites you. ex ford dealer )</font>
Well, I figured I would just run it into the ground. I need a work truck to bang around and play with, and it's running okay so far. Seems okay for a 20-year old truck. If it dies on me, I still have my car, I suppose.
Has this particular model had any problems? I hope not epxloding gas tanks like Dateline showed on those GM trucks about 10 years ago. Thanks for the warning.
Bob
</font><font color="blue" class="small">( Shell Rotella T 15W-40 oil, WIX filter. Simple and probably under $20 for everything. You'll have to do it though. )</font>
Just a follow-up. Thank you! Changed the oil today. Took 7 quarts of the Shell Rotella T. But I only replaced one filter since I didn't realize it had two oil filters and only bought one. Hope this will be okay until the next 3000-mile oil change. I assume like a car that I need to change the oil every 3000 miles? You were right about oil and filter being less than $20.
Also, replaced the front shocks. Tomorrow will replace the fuel and air filters, flush the radiator, and check the electrical system as the right turn signal is flaky.
Bob
</font><font color="blue" class="small">( Your vehicle has a Mazda 2.2L engine based on the old cast iron head series engines mazda designed back in the 60's. Good dependable engine. Parts availability might be tough, but you shouldn't really have any problems. Spring for the Factory service manual on ebay or a swap meet.
Keep it and run the wheels off. - 86turbodsl = an EX- Ford Powertrain engineer )</font>
Thank you, again, 86turbodsl. I'll look for the factory service manual as you say. Will come in handy for my planned retrofit.
Bob
</font><font color="blue" class="small">( At my local napa, they have pretty much valvolene products. That includes the stuff for gas engines.. and their 'fleet' products for diesel. Just look for their diesel oils and grab a 15/40 The filter should be listed up in thier application chart.
Soundguy )</font>
Thank you for your input, Soundguy. We don't have Napa here for some reason but Autozone and Advanced Auto. But I'd imagine they are all the same service-wise.
Bob
</font><font color="blue" class="small">( What a great find!!!
)</font>
Thank you for the reassurance, hwew. I was starting to get worried about this truck.
I greatly appreciate the details you've provided about the engine. Will be very helpful.
Bob
23311 (A51694)
23311 (A51694)
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
Utility Trailer (A52377)
Utility Trailer...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
