1984 1710 Hydraulic malfunctioning
   / 1984 1710 Hydraulic malfunctioning #1
JFS2295
Jersey Shore
None
I've not run my 1710 for a few weeks and went to use it today but the hydraulics were not working well.
History Usually no problem with it, but one winter I did have an issue where the hydraulics would not work below freezing until the tractor warmed up, which I attributed to water inclusion. For the twenty-five years I've had this tractor the hydraulic fluid always turns milky after a few months even through its shedded. I've checked venting and sealing but it always gets milky, so I normally change the fluid and filter every year even with low hours. During the last few uses I noticed the FEL hydraulics were a little slower, even the bucket drop with the float position. Fluid was changed last spring and it probably only has 20 hours with it.
Today started it up (65°F) and the bucket would almost not move. Had a little jittering like it had air, too (shows 1/2 inch down on the dipstick). I could get it to move and curl, and it would lift heavy weight but very, very slowly. 3 PT was sluggish too. This unit has a Tesco remote valve as of a few years ago, FYI.
I HAD to use it for a short time so I did. I was going to change the hydraulic filter as its acting almost like it has a plugged filter (never had that before though), but since I was short on time and would rather change both fluid and filter together, I left it alone for now.
But here is the curious thing once again the FEL float is as slow as the powered hydraulics. I would have expected that to just dump into the reservoir of the gear case or bypass within the FEL circuitry. I probably should have tried dropping the bucket with the tractor not running, but didn't think of that until I was writing this.
Anyway, in a few days I'll be back to the farm to try to understand what is going on, but was wondering if anyone had this issue before or any suggestions?
Thanks.
   / 1984 1710 Hydraulic malfunctioning #2
If you have quick disconects on the loader I would check them first. Un hook and rehook them and see if it helps. The remote valve isn't on is it.
Bill
Thanks Bill. I'll put that on the checklist. Now that you brought it up, a few years ago I did have a QC give me issues, which was replaced.
I cycled through the remote valve just in case. Wasn't it. But have thought of pulling the plate and putting in the OE just to take it out of the equation.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
