1989 260c ford 4x4 with left hand forward/reverser trans.
   / 1989 260c ford 4x4 with left hand forward/reverser trans. #1
hodgejunkie
Ford 545D
This tractor has a pto with (8) forward (8) reverse trans. How will this trans. handle extended bushhogging and disking? Will trans. have slippage after heavy use? How will this trans. compare to standard 8x2 trans.?
   / 1989 260c ford 4x4 with left hand forward/reverser trans. #2
i has a mechanical shuttle so you will not have any slipage
   / 1989 260c ford 4x4 with left hand forward/reverser trans. #3
Actually, this is a power shuttle transmission, but the PTO is independent of the transmission. It will handle the bushhogging fine. The disking depends on the size, but if you are talking 6' or so, it should be okay.
Beware, the torque convertor lockup button on the F/R shift handle IS NOT FOR HIGH DRAFT LOADS such as disking. It was intended for locking out the torque convertor for light loads like bushhogging.
MUSTANG MTL320 SKID STEER (A52707)
MUSTANG MTL320...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
1996 JCB 506B Telehandler (A57024)
1996 JCB 506B...
