1989 Honda trx300 Carb rebuild
   / 1989 Honda trx300 Carb rebuild
Yeah sounds like you have it under control, however you did completely disassemble the carburetor taking out all the rubber parts correct? If not most good carburetor dips will damage or dissolve the rubber parts. You have a CV type carb and it has a big diaphragm in the top of the carb that needs to be removed. And don't be intimidated it functions pretty much the same as any other carburetor.
Left the gasket in the bowl, but i have a kit so thats no big deal, learned the hard way on the fuel lines leaving them connected....but that vorces me to replace those anyway, which needs to be done on a 20+ year old machine. Which looking at those soft screws i dont think it has been into. As for the diaphram i took it off the top and its NOT in the cleaner as i did not know what would or would not be in the kit. So its basically the main body and the bowl, i also took off that air control screw gasket/plate thing, and its not in the cleaner.
   / 1989 Honda trx300 Carb rebuild #12
Well you know what your doing sounds like. Most people don't and stick the whole thing in and end up with a gooy mess. Be carefull with that diaphram because sometimes those become obsolete and finding an NOS part is hard. Drop me a line on my website if you need any tuning help.
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
Morbark Wood Chipper (A51573)
Morbark Wood...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
