1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever
   / 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever #1
buildinit
Rusk, Wi
John Deere 955
I have a 1991 John Deere 955 with just over 3200 hours. It just recently developed a diesel fuel leak on the top of the motor near the rearward "glow plug/injector/bolt cap looking thing with fuel line going into it" area. I don't have the motor tech manual so I cannot tell you exactly what part it is.
I filled it with fuel yesterday and may have spilled on top of the motor. But I started it and ran it for a good thirty minutes yesterday after fuel up, and cleaned up the fuel off the floor and re-parked it. The fuel did not dry off the top of the motor during that 30 minute run, the motor seemed very cool; it was like 15 degrees yesterday. Today I go out there and there is a small puddle of fuel on the floor and that area on top of the motor still looks wet. It's not engine oil; it's absolutely diesel. Anyone have this issue before? I picked up some engine degreaser and carb cleaner to try and determine if there is a source to the leak.
Also, I cannot get the e-brake to engage, any advice? I greased the pedals and all points as per the manual.
Also, my actuator linkage for the FEL needs replacing as well as the oins. Any advice.
Thanks a ton.
Luke
Re: 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake leve
I found out that the rubber fuel line is dry rotted and slowly dripping. Still have not figured out the e-brake!
   / 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever #3
e-brake... meaning the Park Brake ?
rubber fuel line... are you replacing this?
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
