1993 John Deere 544G Loader
   / 1993 John Deere 544G Loader #1
kingriver
We are changing the oil in this unit, the filter is located vertical and mid engine. their is no way to pre fill the filter, the book says to remove engine shut off fuse, crank for 10 sec using starter motor[ then install engine shut off fuse. 1st off dont have that fuse, secondly unless this oil filter has an inline check valve wouldn't all the oil just run back into the pan once the unit is shut down anyway ?
thanks/U]
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
