2 hydro pumps vs 1 (Cub Cadet) vs (Kubota)
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #1
Bamacummins
Bronze Member
Chattanooga TN
Even though I am mostly convinced that the BX tractor is the way I want to go and have heard nothing negative (thanks to all the input on this forum), I still decided to visit my local Cub Cadet Yanmar dealer. He has a model SC 2400, 24 hp diesel with loader and MMM, which is identical to what I want with a BX 2360 or 2660 model. The customer rep was at the dealer and when I told him what I was looking for and comparing too, he began to explain their leg up on Kubota with 2 hydraulic pumps and how that I can use all the implements fully and not be concerned about loss of use in any area due to hydraulic pressure. OK, I admit I'm a novice about all this tractor stuff even though I do understand hydraulics. But he told a story about a man testing a tractor out at a show that owned several Kubotas. He loved the machine and liked them better than Kubota because when he uses is BX for loader work (i.e cleaning out horse stalls) he hates that sometimes he loses power steering temporarily due to the loading and pressure needed to operate the loader. One pump trying to do everything vs 2 pumps on the Cub.
Any opinions on this or should I be the least bit concerned? Does this happen?
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #2
I have to admit I know nothing about Cub Cadets. I looked at them several years ago when I bought my first Kubota and the quality did not match the Kubota, so when I decided to buy a new one, I didn't even look at them. (I just checked the website and couldn't tell much.) I owned a BX2200 for five years and now my BX2660 for about six months or so and have never run into a "problem" brought on by having only a single hydraulic pump. Absolutely nothing has ever happened while using my FEL, but on occasion while mowing, if I raise the MMM while actually turning the steering wheel, I will get a slight "bump" (best I can describe it) in the steering lasting a fraction of a second. I am very happy with my Kubota, but beyond that I am afraid I can't be much help as things that are important to me may not be to you. Good luck.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #3
Perhaps the man was running an older Kubota with a lower GPM pump.
I have a Bx1830 with a mmm, loader, ps, and various rear attachments. I have never lost power steering ability, nor experienced a degraded loader or hst performance. From what I can tell, the hydraulic pump on my tractor is perfectly sized for the size tractor.
The curl cylinder on my loader could be a tad larger though :)
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #4
Ive got over 300 hrs on my 23 and never noticed power steering missing a beat while doing loader work
tom
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #5
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #6
I've never experienced any steering/fel problems while using both. Sales men/women of any product get info concerning competition and each manuf puts something a little different in their product. That's what's pointed out even if it's of no significance. Some cars now have cigeratte lighters standard and the sales force will point this out that theirs are included but the others dealers charge for this. So what. I compared Green, Blue and Orange before I bought mine. Green was $3000 more and maybe their hook was brake somewhere different or something. Blue would lift like 60lbs more at 3ph for only $2000 more than Orange. Have never had an issue with 3ph lift power. I guess your still waiting to sell house before purchasing your Kubota. Visit more branded dealers and see what each one tells you why their product is better than all the other tractors. It can help you kill time till you buy.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #7
I have felt the "bump" before when I had my 2350. Happened with loader work or any lift work when running lower to medium RPM's and quick turns or changes in direction on the steering wheel. Felt like the pwr steering gave out for just a split second until the pump could catch up to the demand. I now have a 2920 which has two pumps and I have not experienced it yet. If I was too look at the "BX" sized tractors again and single or two pump unit would be a selling point for me, leaning towards the two pump tractor.
Have fun in your search...
Tom
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #8
its one of those things that in theory has some merit, and in exactly the right circumstance you maybe able to show a difference... but in practice really is not a big deal.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #9
I've watched a lot of demo's staged for dealers and salesmen. I've read more phamplets then I probably should have. There are companies out there that advertise their equipment at 110% of what it is capable of and some that are only at about 95%.
Then we have the I heard, someone saw!
I tell have seen very few companies that have gone backwards on new equipment design and function. I've seen some that have lowered their quality but they also came with new bells and whistles.
Some won't make the twenty year test and over the last forty years I've seen plenty of that!
For the most part you can never compare a item from ten years ago to todays units.
Last models short comings should have been updated and might be above the rest of the industry.
   / 2 hydro pumps vs 1 (Cub Cadet) vs (Kubota) #10
I've never had a problem with my BX2350. The only thing I've notice is some feed back in the steering wheel on occasion. Say I raise the deck and when it bottoms out and the pump goes into relief, I will feel a slight bump in the steering wheel, but no loss of power steering. In my opinion, it is a non issue dreamed up as a sales gimmick.
500 Gal Fuel Tank (A50121)
500 Gal Fuel Tank...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
