2 point to 3 point hitch
   / 2 point to 3 point hitch #1
lstork
I bought my first tractor last week it's and 806 with a 2 pt hitch. I need to buy the arms to convert it to a 3 pt hitch. My question is the distance between the center of the two arms is 30 inches which I guess is not standard. What do I do? I bought a 3 pt bush hog and would like to be able to use it but can't at this time. Where can I find a 3 pt conversion for this. I guess standard distance is 26" or 32". I'm new to all this tractor stuff and my dad is on the road and can't offer his knowledge.
   / 2 point to 3 point hitch #2
We have those arms that are offset to put you back to category 1 spacing. Just call us to place your order. Ken Sweet
Isn't category I for smaller hp tractors?
   / 2 point to 3 point hitch #5
Istork, Normally with that big 806 tractor, You would use straight tongs normally with catagory 2 (1 1/8 inch ball holes). We also stock a straight tong with a ball that has catagory 1 ( 7/8 inch and 1 1/8 inch all in the same ball) If you need to go narrow, you would use the bent tongs that are curved inward to be the same width as catagory 1 spacing or turn them outward for catagory 2 spacing. Ken Sweet
   / 2 point to 3 point hitch #6
I have a 756 International with two point, bought arms with ball that fit and all I need to do beside that was get a longer top link. Got that at Tractor Supply. They also make an sleve to go on three point lift points that enble you to use the two point as well. I use those when I use the rottery cutter.
Bobcat 5600 Toolcat UTV (A49251)
Bobcat 5600...
Allis Chalmers D17 Tractor (A49339)
Allis Chalmers D17...
Hunter TCX620 Tire Changer (A46683)
Hunter TCX620 Tire...
Golf Cart (A48082)
Golf Cart (A48082)
RTB Half Bar Hay Saver (A49251)
RTB Half Bar Hay...
2014 Dodge Journey SUV (A46684)
2014 Dodge Journey...
