2 way clutch. Does it need overrunning clutch for use with Bush Hog?
   / 2 way clutch. Does it need overrunning clutch for use with Bush Hog? #1
msjanket
My Massey 130 has the 2 level clutch. When using my Bush Hog, do I need to install an overrunning clutch with it, despite the fact the second stage of the tractor operates with a separate shaft from the engine compartment?
   / 2 way clutch. Does it need overrunning clutch for use with Bush Hog? #2
No. If it was needed MF would have built it into the tractor.
   / 2 way clutch. Does it need overrunning clutch for use with Bush Hog? #3
Only way you need one is if the tractor has a "transmission" driven PTO like my 4 speed 2000D. The Live PTO is a separate powered shaft which you can connect/disconnect with the second clutch plate controlled at the bottom end of the clutch pedal travel. I have one of those on my 3000D and for setting post holes you can't beat it in my opinion.
Mark
   / 2 way clutch. Does it need overrunning clutch for use with Bush Hog? #4
If you can stop the tractor and still allow the PTO to turn without it pushing you forward, then you don't need an overrun clutch. Overrun clutches are only needed to keep the inertia of a bush hog from pushing you forward when you push in the clutch on a tractor without live PTO.
   / 2 way clutch. Does it need overrunning clutch for use with Bush Hog? #5
What others said.
You have the live PTO (2-stage clutch). IT is not needed
INTERNATIONAL S/A GRAIN TRUCK (A52708)
INTERNATIONAL S/A...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
Rooster Weathervane (A55853)
Rooster...
1288 (A58374)
1288 (A58374)
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
