renegade2k
- Joined
- Aug 31, 2010
- Messages
- 1
I have the above Opposed twin engine in a Murray lawn tractor and it runs great until I go up a hill with the blades on, or I mow above half speed.
I would expect that an engine this size would handle mowing at full speed(with the obvious bad Cut), but would not drag the engine slow.
I have tried pulling the choke, but it only makes it worse.
I am used to adjustments on tractor carbs, but the jets are not adjustable.
I am unfamiliar with this engine and don't know if the fuel pump on the carb could cause this problem.
I did notice that fuel comes out of a brass tube in the carb (on the wall with the fuel pump) when the engine is running with the air filter off. The fuel is usually sucked into the carb. I don't know if this is normal or not.
