Oil & Fuel 2000 4 CYLINDER FORD REAR OIL INLET LINE ON ROCKER ARM VIBRATES
   / 2000 4 CYLINDER FORD REAR OIL INLET LINE ON ROCKER ARM VIBRATES #1
Tikk66
I have my grandfathers 1963 4-cylinder ford tractor. It has a little over 1600 original hours. Lately a light "pecking" started and I assumed the valves needed adjusted. I removed the valve cover and started the motor. The "pecking" immediately went away. I noticed the rear oil inlet line to the rocker arm asssembly was vibrating excessively up and down. I looked on the inside of the valve cover and seen a small spot where it had been rubbing. I can hold the line down and it will stop vibrating. Does anyone know what can cause this? can you see the other end if you take the side cover off?
Any advise would be greatly apprecited.......Tikk66
   / 2000 4 CYLINDER FORD REAR OIL INLET LINE ON ROCKER ARM VIBRATES #2
There is a rubber grommet that is supposed to seal the lower end of the tube. if it is bouncing up and down, there probably is no oil being supplied to the rocker arm shaft. After 45 years, the grommet has given up.
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
Electric Forklift Pallet (A50322)
Electric Forklift...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
