2001 Bobcat 873 dies when is not level?????????
   / 2001 Bobcat 873 dies when is not level????????? #1
lawnboy83
Louisville ky
bobcat 873
I have a Bobcat 873 that dies everytime its not level. Loading and unloading from trailer. This is getting to be aggravating I changed every filter today hoping that might fix it but still does the same thing. Please any help would be greatly appreciated.
   / 2001 Bobcat 873 dies when is not level????????? #2
Fuel pick up tube is broken or cracked in tank.:thumbsup:
How big of a job is that to replace?
   / 2001 Bobcat 873 dies when is not level????????? #4
Fish it out with a wire and stick a new one on.
   / 2001 Bobcat 873 dies when is not level????????? #5
How big of a job is that to replace?[/QUOTE
fuel pickup and fuel return hoses go into top of the tank somewhere between the engine and hydrostatic pump (actual location was moved a couple times throughout production of this model due to design changes). Usually it is tuck up close to pump. The barbed fitting going into the tank passes through an expandable rubber bushing. To Remove; pull up and twist the bushing. It will pull out. Use a new bushing when you reinstall. If the pickup tube is hard straight plastic type most dealers replace it with hose about 1.5 - 2 times longer than original tube and install p/n 6650239 brass fuel screen on end of hose.
Thanks for all the help greatly appreciated
   / 2001 Bobcat 873 dies when is not level????????? #7
Check the oil level. Might have a low oil shutoff.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
