Oil & Fuel 2003 jinma 224 fluids and filters
   / 2003 jinma 224 fluids and filters #1
mak56
2003 jinma 224
Does anyone know the american fluids and filters I should be using on this tractor. Bought it used and want to get them all changed. thanks
   / 2003 jinma 224 fluids and filters #2
Oil = 15W40 Diesel rated oil
Gear boxes and front axle = 80W90 Gear oil
Hydraulic sump = AW32 Hydraulic oil
Injector pump = Either 30 weigh Motor oil, ISO 100 Compressor oil, or 15W40 Motor oil (yes, the injector pump does have its own sump for lubricating oil and must be changed ever 100 hours max or once a year)
I change my oil ever 50 hours. Injector pump every other oil change. Gear boxes after the first 50 hours then at 250 hours then every 250 hours after that. Hydraulic fluid ever 200 hours of so.
I do not have the same tractor as you so I will let someone else give you the filter numbers.
Chris
   / 2003 jinma 224 fluids and filters #3
I change my oil filter every 50 hours (sooty little buggers), and the oil by analysis. So far the oil has over 200 hours on it and it's still very good.
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
