2004 Kubota 3130 leaking oil from drain plunger
   / 2004 Kubota 3130 leaking oil from drain plunger #1
cyclepainter
I have a 04 3130 4wd with a DT trans. 209 hrs. that just started to leak oil from the drain plunger which is located about mid belly on the tractor. my local dealer says it could be a seal from the engine or 4wd. It is a dark , not red, colored oil. It only leak about a 2-3 inch circle after I use it and load it on the trailer. I hope this is a warrenty item, but has anybody ever had this problem?
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
Excavator Mounting Plate (A50775)
Excavator Mounting...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
(6) New 2x15 E-Track Ratchet Straps (A54865)
(6) New 2x15...
