2004 New holland ts100a drive shaft leaking on the rear seal
   / 2004 New holland ts100a drive shaft leaking on the rear seal #1
dbbtractor
New Holland TS100a
It's the drive shaft that leads from the rear end to the front differential, we have replaced the seal and it still leaked then we did the seal and o-ring and it still leaks. I'm not the one that replaced it, it was my dad and he doesn't pay attention to stuff as good as I do so there could have been another problem like metal worn off of something which caused it to not have a could seal. I do know that the carrier bearing (I think is what it's called) that supports the middle of the driveshaft was loose. But it started leaking almost right after we fixed it and drove it. The trans case also bolts together right there which means there痴 a gasket there, I had the suspicion that it was leaking through there because the paint has come off in a spot right on the gasket but it痴 clear that it痴 coming from the seal.
   / 2004 New holland ts100a drive shaft leaking on the rear seal #2
First culprit would be the shaft. Any little imperfection will equal a leak. Worse could be play in the actual output shaft that drives it. I could be wrong. Just a couple of things to look at.
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2024 FORD F250 SUPER DUTY BED (A58018)
2024 FORD F250...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
WATER TRAILER (A58214)
