2005 Diesel HPX questyion re 12 volt accessory outlet
   / 2005 Diesel HPX questyion re 12 volt accessory outlet #1
kude
Brothers,
I had the dealer come out during the winter to get the snow blade working (a recurring problem, works fine all year until you get a snow day, go figure).
Anyways after they left I found a a round cynlinderical flasher module on the floor. I then noticed my flashers didn't work and the 12 volt accessory plug had no juice. I now need the plug for my tank sprayer.
I took photos of under the dash and found where the flasher module plugs in. So okay, I now know where this module plug goes. I notice a red/black pair plug dangling in the are near the module, is this an extra power cable with connector? Or should this go to the power outlet somehow?
Does the flasher module have side effects like knocking out the power outlet?
Thanks for any pointers.
   / 2005 Diesel HPX questyion re 12 volt accessory outlet #2
Yes the red and black connector is 12 volt battery power. It is protected by a 40 amp fuse. So plan accordingly with your electrical load. There is one of the plugs in the engine bay also on the right hand side. It may be safer to just hook a harness to the battery. The flasher module should not knock anything out physicaly. It does add to the electrical load on that 40 amp fuse as does all the electrical add ons.
Thanks, I'll look for the engine bay plug for the spayer (I have been routing power to the sprayer through the door). I did get the flasher plugged in, that works. I recall trying to start the HPX with a Black and Decker Start It battery pak using the acdcesory plugin. I checked the fuse (10 amp) under the seat for the accessary plug and the fuse was blown. Yeah those plugin starters don't work right, IMHO if they blow the fuse. Always jump to the battery.
At least I know there is a power connector available under the dash for a radio or something.
Again thanks for taking the time to respond.
   / 2005 Diesel HPX questyion re 12 volt accessory outlet #4
just asking a uestion here . bit if they was workin and the stuff was hooked up before they got there and they took this stuff and disconnected it why not make another phone call and ask why they took it off and tell them you would like them to put it back on??
kude said:
Brothers,
   / 2005 Diesel HPX questyion re 12 volt accessory outlet #5
Your welcome and good luck!
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Kawasaki NR (A50324)
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
