2006 Massey 1533 PTO will not engage
   / 2006 Massey 1533 PTO will not engage #1
busdriver5097
Lexington, SC
MF 1533
I have checked the gear lever and in neutral the shaft turns free, in forward position pto will not turn. When I turn the yellow knob, the indicator light on the instrument cluster comes on and yellow button lights up. Whether I push the yellow button or not the pto shaft will not turn under its own power. Is there a switch or solenoid to check? If the solenoid is bad will the instrument cluster light still come on?
   / 2006 Massey 1533 PTO will not engage #2
I could be the knob or the fuse or a solenoid on the firewall. You can snap the rotary switch apart to clean it up an put some grease on. The PTO has a electro-hydraulic clutch. A lot of help huh? :confused2:
I'm thinking a solenoid of some type. I wondered if the instrument cluster light would still come on with a bad solenoid.
I'm sorry I forget to thank you for responding. I do appreciate any help.
   / 2006 Massey 1533 PTO will not engage #5
Busdriver5097,
I know this was a while back but I'm having same issue on my MF 1533. Did you ever figure your issue out?
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
