2007 John Deere 4520 For Sale
   / 2007 John Deere 4520 For Sale #1
Ridgeman
SE Ohio
JD 4520, JD 595SE, Gator HPX, JD 997
2007 John Deere 4520 Tractor 4wd - asking $25,000
eHydro transmission, 400x front end loader
356 hrs, turbocharged diesel engine
53 hp, one set rear remotes, rear wheel weights
3rd Hydraulic line to front for grapple, etc.
rear work lights, I-Match, load match
Dual hydraulic pumps ensure a consistent fluid flow for steering and a separate supply to implements
two buckets - 1 regular with replacible cutting edge and a 4 in 1 bucket which uses the 3rd hyd line to front
I bought the tractor new and now have no use for a tractor anymore
Also have an MX6 Rotary Cutter, a Frontier 84" rear blade, a Sitrex 90" rear discharge finish mower, a Speeco post hole digger with 12" auger
740-532-2563 or 740-646-4530
I may have the wrong section for this and appoligize in advance if I do.
   / 2007 John Deere 4520 For Sale #2
You will probably get better results by posting in the "Private Party Ads" forum here on TBN. Best wishes.
Thanks! I was looking for that but couldn't find it
(2) 300 GALLON POLY TOTES W/CAGES (A60432)
(2) 300 GALLON...
PIN PULL AERATOR (A60430)
PIN PULL AERATOR...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
