2007 New Holland TC30 Oil and filters?
   / 2007 New Holland TC30 Oil and filters? #1
plasmacon
Benton, KY
I've got a 2007 New Holland TC30 that has a frame mounted back hoe and front end loader. I'm located in western Kentucky, and I am not sure what I need to do maintenance wise. If some one could tell me what oil and filters I need to change, I would greatly appreciate it. I've had it for a couple of years and it has 150 hours on it. I need to know what to buy, brands etc if some one is willing to take a few minutes. What all should I do? Oil, fuel, hydraulics, grease etc? My manuals are in storage, lost until who knows when. Just a quick list of filters, grease, and oils would be helpful. Thanks Patrick.
   / 2007 New Holland TC30 Oil and filters? #2
Welcome!
oil-any 15W40 motor oil will be fine-diesel rated,Shell Rotella is very popular.
oil filter-Carquest 85348,Wix 51348-very common
If you have the hydrostatic transmission,the service interval is first change with filter at 50 hours,about 8 gallons,every 600 hours after.
grease-moly-disulfied black grease is an excellant low cost choice.
More questions?Post back or post the questions on the New Holland owning and Operating Forum.
Good Luck!
Thank you for your response. I guess I have some other questions. A mod could move this to the New Holland Operating forum if needed. Otherwise, I will finish this thread and post there in the future.
1. What do I need to do for a manual transmission?
2. What kind of hydraulic fluid and filter to use?
3. Do I just hit every grease fitting, or are there any I should avoid?
4. Are there any issues I need to be warned about with this tractor?
I dont think anything has been done to the tractor.
   / 2007 New Holland TC30 Oil and filters? #4
Your tractor will use the same fluid for the transmission,hydraulics,and final drive.Universal Tractor Fluid(UTF)meeting the Ford/New Holland 134 spec such as New Holland Ambra-very common.
Hydraulic filter-Carquest 84098 or equiv.
The loader and backhoe should be greased every 10 hours,or so.The tractor itself a little less often.
Your TC30,used to be a Ford 1610?,Shibauru unit made for decades-good basic unit.
Even though you can't locate you operators manual,you really need to obtain one.It will give fluid capacities,drain and refill instructions,etc.Maybe 20 bucks at a dealer or online.
Once again,unleash your questions on the New Holland forum for much better answer answers than I can provide,and most likely more than you care to read,Good Luck!
   / 2007 New Holland TC30 Oil and filters? #5
When I bought mine the dealer said 30wt oil was fine in the hydralics
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
