2008 TE254A Foton Tractor Gear Oil Pump problem
   / 2008 TE254A Foton Tractor Gear Oil Pump problem #11
Wow - it worked. Learn something new each day. Never had the need to do that before - sorry about that.
Hope the manual helps.
Cheers
   / 2008 TE254A Foton Tractor Gear Oil Pump problem #12
If the system has a loose screen in the sump under the seat in the hyd suction line it will (even when pressurizing the sump) not suck fluid as the air will push into the pump suction in place of the fluid.
Other thing is to crack the line at the pump inlet and see if pressurizing the sump pushes out fluid.
As for the pump, yes two bolts hold pump to engine AND keeps the 3 parts of the pump together and the other two bolts just hold the pump parts together. NOTE: these bolts are not super tight as the pump has to turn but the gears and body are almost exact same size (very tight clearances.) If the bolts are too tight then the pump may actually bind up keeping the engine from turning over. There are rebuild kits (o-rings) that you can also rebuild the pumps with. Again you have to leave the pump shells loose and then start to tighten them some to make the seal without over tightening them locking the pump...
Mark
Well I had a bit of bad luck. Well I was at my Dad's place and as we were backing it out of the garage with my brother at the wheel, the garage door caught the door handle on the tractor and shattered the whole glass door. I am so disappointed. Anyone know where I can get a replacement glass door preferably in Canada? Left side cabin door.
   / 2008 TE254A Foton Tractor Gear Oil Pump problem #14
Check out this link - Asiantractor parts:
Jinma Tractor Parts - Foton Parts - FarmPro - Asian Tractor Parts
They are in Ontario and I have found them to be very good. Reasonable prices and quick delivery and they will use Canada Post instead of the couriers (Fedex, UPS etc.) if you want. Might take a while but I am sure they will be able to help you. Plus, there will be no cross border shopping hassles.
Cheers
Thanks Jim I just emailed them hopefully they can help me out
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
FAKE (A52472)
FAKE (A52472)
1989 14ft. Gamefisher Aluminum Jon Boat with Trailer (A51694)
1989 14ft...
2024 Polaris General XP 1000 Premium  (A52384)
2024 Polaris...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
