2009 XUV clutch engagement
   / 2009 XUV clutch engagement #1
xmoto
Bronze Member
Upstate NY
Kubota LA3410, Ford 3400, Gator XUV
I HAVE A NEW XUV 620. IN MY WOODS THERE ARE A LOT OF PLACES I HAVE TO GO VERY SLOW. IT SURGES AND IS HARD TO DRIVE SMOOTH AT VERY LOW SPEEDS. IS THERE A FIX FOR THIS. MY BE A LOWER CLUCH ENGAGEMENT SPEED? ANYONE HAVE ANY IDEAS.
   / 2009 XUV clutch engagement #2
Either run in low gear, or slighly keep your foot on the gas so it doesn't freewheel. I had the same experience with my 850D but I got used to it and it isn't such a problem any more.
The engine with help with braking as long as the clutch is engaged but when you slow down enough it disconnects completely (freewheels) and then you'll start coasting much faster. Getting back on the gas re-engages the clutch and it's like poppling the clutch on a standard drive car, a jerky manuever.
Plus, you'll probably get happier with the brakes over time. Mine felt weak and took a while to bed in properly but now they're fine.
Finally, another technique would be to drive with left foot braking as needed and keeping the right foot ever so slightly on the gas to keep the clutch engaged. I don't drive this way but there are times when I thought I ought to try it.
Engoy your machine.
   / 2009 XUV clutch engagement #3
i have noticed this mainly when riding passenger in mine also. it feels like a combination of smooth efi throttle resonse and a very soft gas pedal.
Maybe a little stiffer gas pedal would help.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
PICKUP TOOLBOX (A58216)
PICKUP TOOLBOX...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2005 John Deere 200C LC (A55272)
2005 John Deere...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
4ft Quick Attach Disc Harrow (A57454)
4ft Quick Attach...
