2010 Cub Cadet Volunteer 4x2 transmission service
   / 2010 Cub Cadet Volunteer 4x2 transmission service #1
RadioRalph
Valdosta Ga.
Farmall Cub
It's time to service the transmission..the current transmission has almost 50 hours..and is a warranty replacement.....manual calls for approx 64 ozs of fluid, I just drained the fluid and might have 32 ozs total in the bucket,also the drain plug is in a different location than shown in the manual and requires an allen wrench for removal,the plug to add fluid is as shown in the manual.I need your advice, should I add the same amount that drained out, or add till the fluid flows out, as stated in the manual. With the drain plug in a different location do I have a different type or version of transmission,that might use a different type or amount of fluid? The transmission is very clean, no sign of any leakage...this is a 2010 volunteer,4x2 model37bb475h010. Thank you.....RadioRalph
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
John Deere 1025R (A53317)
John Deere 1025R...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
John Deere 5105M (A53317)
John Deere 5105M...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
