2010 Kubota 900 RTV hard starting when cold
   / 2010 Kubota 900 RTV hard starting when cold #1
Fastfords
2010 Kubota 900 RTV
My Kubota is very hard to start in cold weather. I thought it may be the battery or alt. but both tested great.
I have to cycle the glow plugs for about 45 seconds or so 3 or 4 times for it to even try and start. It's very slow turning over. Most times it will start but it is very hard to get going.
In warm weather I am good to go, starts up with no issues.
Looking for some help figuring out what is gong on.
Thank you
   / 2010 Kubota 900 RTV hard starting when cold #2
A lighter oil may help cold weather starts. If you've load tested the battery clean connectors and cable ends reinstalling TIGHTLY. Look carefully for signs of corrosion around the connectors. Clean and tighten ground contact at frame.
   / 2010 Kubota 900 RTV hard starting when cold #3
When I lived in Wisconsin I used 10W30 syn oil in my truck and
car and never had a problem with starting
Here we seldom see any freezing weather I use 15W40 and
even when the temp drops below freeZing I still have no problems
Have you checked your glow plugs?
willy
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
John Deere 1025R (A53317)
John Deere 1025R...
2014 DORSEY EXPANDABLE FLATBED (A59575)
2014 DORSEY...
