2013 Kioti CK35 HSTS Axle drain plug leak
   / 2013 Kioti CK35 HSTS Axle drain plug leak #1
WiKioti
Eau Claire, Wisconsin
CK35
:eek:On the left rear side of tractor as you are sitting on the seat, the drain plug is leaking. It is snug and tight. Last year I changed oil and everything has been fine till about a month ago I noticed fluid on floor of pole shed.
I wiped this area clean, and sure enough the drain plug a minute later is leaking. Local dealer, said to buy and install an new drain plug. Duh.
Anyone have this issue or is there a gasket plastic or otherwise to seal this up. Any ideas are great, even though I have to drain it again just to fix problem.
this baby runs just great, with about 150 hours on it now.
Wikioti
   / 2013 Kioti CK35 HSTS Axle drain plug leak #2
I have a 2005 CK30hst. My drain plugs have gaskets. I haven't had a problem with them leaking after 4 oil changes.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
