John Dougherty
Bronze Member
I don't know if this is the proper protocol for this thread as it covers a previous discussion about this same issue, but it might save some reading. My original issue with my BH was that it lost most of its' down force and on retraction the boom would slam back to the stowed position. Control was erratic at best. The clue to the solution should have been the slack that was present in the control lever. There was approximately 1/4" of travel with nothing taking place. Full disclosure: originally I thought that I could feel the spool when in the blind I put my finger into the positioner behind the hydraulic hoses and moved the control lever. I assumed that the positioner had blown its' guts out so I purchased a new one. As it turned out that was not the case. I did end up using the new one since the original had a bit of crap in it due to a missing protective cap. Would the old one have still worked? Probably, but I'm not returning the new one so...
The repair is pretty straight forward: Release any pressure on the implement and turn the engine off. Remove the two bolts that hold the metal shield covering the valve body, remove the metal cover. Loosen the the two hydraulic hoses directly in front of the positioner to be removed. Back out the positioner completely. If using the original positioner or a new one, put some locktite on the threads that extend from what looks like a bolt end at the top of the positioner. Hold down the control arm while threading the positioner back into the valve body. This took me three tries to get it started into the spool (round shaft being actuated by the control lever). These threads will make contact before the threads on the positioner body itself. The positioner will resemble a chainsaw sparkplug wrench w/o the screwdriver handle for the boom. Other positioners are shorter. Note that the control lever now has no slack when moved. This will tell you that you have successfully started the 'upper' threads into the spool. Re-attach the two hydraulic hoses and start the tractor to test the BH action. If good, then replace the metal cover over the valve body. I could not have done this w/o the help of Rob at Dave's Tractor. While this does not seem to be a wide spread problem in tractor nation the fact that it happened once indicates it could happen again. Hope this helps someone down the road.
