2014 New Holland Boomer 37 DEF Tank
   / 2014 New Holland Boomer 37 DEF Tank #1
Skybird12209
I am having a problem locating the DEF tank for my 2014 NH Boomer 37. I have a repair manual for it, but don't see where this tank is located. I read somewhere that it should be near the fuel tank, but I don't see such a tank. I have added diesel fuel supplement at the start of winter to the fuel tank, but have not added any DEF to the DEF tank. Would I get a warning on my dash that I need to add some DEF?
   / 2014 New Holland Boomer 37 DEF Tank #2
No tractor under 75 HP uses DEF. In your case, the emission control is done using EGR and DPF. All you have to worry is to check the fluids and bolts every once in a while, fill the fuel tank as needed and run it.
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
