2017 MAHINDRA 3540 SUCTION FILTER CHANGE AND STRAINER CHANGE 50 HR
   / 2017 MAHINDRA 3540 SUCTION FILTER CHANGE AND STRAINER CHANGE 50 HR #1
FORRESTP
ATHENS
MAHINDRA 3540
I have a mahindra 3540 that I just bought with 56 hours on it. It needs to have service done on the oil system, and hydraulic filter and strainer. I have changed the oil system, But now I want to remove the old hydraulic filter and clean strainer as recommended. The hydraulic oil does not need to be changed. My question is, can I leave the hydraulic fluid in the tractor when I am removing the filter to change it and when I am removing the strainer to clean it? Or is the hydraulic fluid going to spill out with the removal of either of these two item.
Okay, I have gotten my answer from a Mahindra tech. If I remove the spin off filter I will loose some fluid it I am fast with putting the new one on, if not it all will drain out eventually. If I remove the strainer to clean it, I will loose all the fluid. Best thing I see is to just drain the hydraulic fluid into a clean catch basin and make the changes then put the fluid back in.
2025 JMR 36in Bucket Skid Steer Attachment (A51691)
2025 JMR 36in...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
377811 (A48836)
377811 (A48836)
