2017 Mahindra XTV 750 Mpact Electrical Issue
   / 2017 Mahindra XTV 750 Mpact Electrical Issue #1
Ernie Beast
Mahindra XTV 750 Mpact and EMax 22
Pulled the battery to put on maintainer over the winter. 4 cable wires, 2 on right frame rail, 2 on left frame rail. I zip tied positive, zip tied negative to keep from confusing when I reconnected. Installed negative cables to battery first. When I started to tighten cables, something arced and put a weld mark on the bolt. What could have back fed current to the negative terminal? The battery was out of the unit for approximately 2 months. I cannot figure out why this happened? I need help please.
   / 2017 Mahindra XTV 750 Mpact Electrical Issue #3
I am not totally clear on what was connected, and when... However, the mistake that is generally made is that people connect the negative cable, then the positive and accidently short to any bare metal.
When removing a battery always remove the negative cable first. When installing the battery always connect the positive first. In any scenario a tool across the terminals is a dead short and can be bad news.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
