2021 Kubota SVL75-2 Track Loader (A56436)
Item Details
Auction ID
56436
Make
Kubota
Type
Miscellaneous
Year
2021
Auction House
Fastline Auction, LLC
Model
SVL75-2
North Carolina
Description: Engine gross horsepower (SAE J 1995): 74.3 HP (55.4 kW) Rated operating capacity (35% of tipping load) : 2300 lbs (1043 kg) Bucket breakout force : 6204 lbs (2814 kg) Operating weight (Including operator weight 165 lbs) : 9039 lbs (4100 kg); Kubotas unique vertical lift is designed to deliver an exceptionally long reach of 41.7 inches (SVL75-2) and 40.7 inches (SVL95-2s). In addition, the tip of the arm is optimally shaped for a tall hinge pin height of 119.1 inches (SVL75-2) / 128.5 inches (SVL95-2s) for easy dumping into trucks. Standard Two-speed Travel Shift from low gear at 4.7 mph (SVL75-2) / 5.0 mph (SVL95-2s) to high gear at 7.1 mph (SVL75-2) / 7.3 mph ( SVL95-2s) to get the job done faster. Pilot Valve with Shuttle Piston This ensures consistent oil flow which improves stability when going straight. Higher Ground Clearance A high ground clearance of 11.7 inches (SVL75-2) / 11.5 inches (SVL95-2s) lets you travel over large obstacles with ease. Strong Traction Force Kubotas original track lug design gives you more grip and a stronger traction force of 9678 lbs (SVL75-2) / 12178 lbs (SVL95-2s). Year: 2021 Make: Kubota Model: SVL75-2 Serial #: KBCZ052CEM1L62991 Hours: 729.0 Stock #: E79347 Enclosed Cab: No Lift Capacity: 2300 FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Fayetteville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 28306 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 13500.00 USD
Auction Finishes: December 16, 2025 at 05:26 PM
Click Here To Bid Now!
Happy Bidding!
John Deere 5075E (A53317)
John Deere 5075E...
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
1996 International Semi (A59814)
1996 International...
