2021 Kubota SVL75-2 Track Loader (A56438)
Item Details
Auction ID
56438
Make
Kubota
Type
Miscellaneous
Year
2021
Auction House
Fastline Auction, LLC
Model
SVL75-2
North Carolina
Description: Engine gross horsepower (SAE J 1995): 74.3 HP (55.4 kW) Rated operating capacity (35% of tipping load) : 2300 lbs (1043 kg) Bucket breakout force : 6204 lbs (2814 kg) Operating weight (Including operator weight 165 lbs) : 9039 lbs (4100 kg); Kubotas unique vertical lift is designed to deliver an exceptionally long reach of 41.7 inches (SVL75-2) and 40.7 inches (SVL95-2s). In addition, the tip of the arm is optimally shaped for a tall hinge pin height of 119.1 inches (SVL75-2) / 128.5 inches (SVL95-2s) for easy dumping into trucks. Standard Two-speed Travel Shift from low gear at 4.7 mph (SVL75-2) / 5.0 mph (SVL95-2s) to high gear at 7.1 mph (SVL75-2) / 7.3 mph ( SVL95-2s) to get the job done faster. Pilot Valve with Shuttle Piston This ensures consistent oil flow which improves stability when going straight. Higher Ground Clearance A high ground clearance of 11.7 inches (SVL75-2) / 11.5 inches (SVL95-2s) lets you travel over large obstacles with ease. Strong Traction Force Kubotas original track lug design gives you more grip and a stronger traction force of 9678 lbs (SVL75-2) / 12178 lbs (SVL95-2s). Year: 2021 Make: Kubota Model: SVL75-2 Serial #: KBCZ052CJM1L63534 Hours: 646 Stock #: E79463 Enclosed Cab: No Lift Capacity: 2300 FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Fayetteville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 28306 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 15000.00 USD
Auction Finishes: December 30, 2025 at 06:14 PM
Click Here To Bid Now!
Happy Bidding!
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
Toro Groundsmaster 400-D (A57453)
Toro Groundsmaster...
