2021 T574 Front Axle oil change
   / 2021 T574 Front Axle oil change #1
Cripler714
2021 TYM T574
What oil is everyone using for front axle? Says 80w90 GL-4, but can't find anything except GL-5. Still under warranty and don't want an issue.
   / 2021 T574 Front Axle oil change #3
The GL5 shas twice as much phosphorus and sulfur as the GL4, the phpspohourus and sulphur react with the metal surfaces of the gears, and form a sacrificial layer which lessens the gear wear.
Shell has a good look up tool, which tells you which of their oils you can use.. And, advent parts house should be able to tell you what matches their recommendations in other brands.
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
1779 (A51248)
1779 (A51248)
