Item Details
- Listing Type
- Auction
- Stock ID
- 61307
- Make
- Kubota
- Type
- Tractor
- Year
- 2023
- Seller
- Fastline Auction, LLC
- Model
- 6060
- Location
- Florida
Description: The Kubota L6060 is a 62 horsepower, four-wheel drive compact tractor with 53 PTO horsepower. It features a turbocharged four-cylinder diesel engine and a hydrostatic transmission with Stall Guard PLUS. Key specs include a 13.5-gallon fuel capacity, a Category 1 & 2 three-point hitch with a 2,976 lb lift capacity (at 24 inches), and a 4,023.5 lb operating weight. Engine and performance PTO: 540 rpm rear PTO standard, with a mid-PTO option Engine: 62 gross HP, 53 PTO HP, four-cylinder turbocharged diesel engine Transmission: HST Plus (Hydrostatic) with three ranges and a 6-speed adjustment via the H-DS handle Drive: 4WD Hydraulics and hitch Hydraulic flow: 9.4 gpm Three-point hitch: Category 1 & 2, with a lift capacity of 2,976 lbs at 24 inches Loader lift capacity: Over 2,000 lbs at the pivot point to full height Dimensions and weight Operating weight: 4,023.5 lbs Fuel capacity: 13.5 gallons Turning radius: 9.2 ft Tire size (front): 9.5-16 Tire size (rear): 14.9-26 Year: 2023 Make: Kubota Model: L6060HST Serial No.: KBUL5FHRVN8L53490 Hours: 2 Meter Reads: 2 Transmission: Hydrostatic Enclosed Cab: No Stock No.: E79778 FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Bradenton Item Location - State/Province: Florida Item Location - Postal/Zip Code: 34212 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
2023 Kubota L6060HST Compact Utility Tractor
see lot description, multiple locations, KY 40010
Starting Bid: 16500.00 USD
Auction Finishes: January 27, 2026 at 04:14 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
