2050 Mits
   / 2050 Mits #1
oliver28472
Veteran Member
Mt. Ulla, NC
Satoh S-470D, Mitubishi FD 1450D
1. A friend has one and I think his glow plug indicator is toast but the plugs are still working. Is that possible? I thought the power went through the indicator.
2. Is there a non grey mits or satoh that uses the same starter switch as this tractor?
   / 2050 Mits #2
I have a D2300 and my indicator doesn't ever glow, but the plugs both heat. Fires up right away, even on these cold (relative, I understand!) winter ones... The indicator is very corroded and I suppose I'll replace it one day, but as long as it works...
   / 2050 Mits #4
Regarding - Is there a non grey mits or satoh that uses the same starter switch as this tractor?
I replaced my D2050 starter switch with a Kubota part. Don't recall the number but I took my switch to the Kubota dealer and he found one that looked exactly the same. It installed with no problems and worked fine.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
