2120 Cavitating
   / 2120 Cavitating #11
Scott,
If you see foamy/milky oil the problem is like you said "air entrainment" and it gets sucked in from an N/G or loose suction line/tubing, or it could be a leaky shaft seal on the pump......clogged suction strainer/filter or oil too thick will compound this condition.....
Best to check all connections and glob grease on the shaft seal if it's out in the open.....
It's rare to have the cyls introduce air as it would need an overrunning load to create suction to have this happen.....
I'd double/triple check all suction connections/piping/hose before proceeding....:thumbsup:
   / 2120 Cavitating #13
I'd unscrew the hydraulic filter and check the O-ring. The filter is vertical on that machine so it shouldn't spill much oil. Check the piece of flex hose and band clamps just before the filter as well.
2011 EDMONTON TRAILER MFG FRAC PUMP (A53843)
2011 EDMONTON...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2019 VOLVO TRUCK VNL (A53843)
2019 VOLVO TRUCK...
MAKITA TABLE SAW (A53843)
MAKITA TABLE SAW...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53473)
Kubota BX2680...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
