2120 HSS Ford Transmission hesitates
   / 2120 HSS Ford Transmission hesitates #1
hcubbie
Dansville, NY
Ford 2120
I have a Ford 2120 with a loader shuttle shift hesitates and moves very slow only moves in Low or Mid ranges. I have changed Hydrolic fluids and Filters and now it seems to be worse. Can anyone give me any Ideas on what to look for.
   / 2120 HSS Ford Transmission hesitates #2
My 1993 2120 op manual spec calls for Ford 134 hydraulic oil or equal, qty. is 34.9 quarts. Did you vary from either spec? Did you use a New Holland hyd filter? Is the hyd showing full on dipstick?
The hydraulics were getting slow or weak before you changed oil - is that why you changed? Have you had the tractor long to know if this is a new problem or slowly getting worse? Does the engine run smooth? Is the clutch strong? How many hours on the tractor?
Need more info.
Jim
I have to check with my mechanic about the filter and the grade of oil I do know that the oil stick shows full. Before all this the tractor would hesitate between forward and reverse otherwise shifted and ran just fine. I will find out the other information on Monday December 30th.
Thank you for getting back to me, we use this tractor for different jobs between two golf courses.
hcubbie
   / 2120 HSS Ford Transmission hesitates #4
As Jim asks, is the clutch strong and is it adjusted. The 2120HSS uses a regular dry clutch along with a forward and reverse wet or hydraulic clutch. Adjustment could be out on one or the other, but I would suspect the main clutch.
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
CAT 973 (A47384)
CAT 973 (A47384)
2018 Vermeer Chipper (A51573)
2018 Vermeer...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2006 International 9400i (A53472)
2006 International...
