2164 with briggs and stratton not charging battery
   / 2164 with briggs and stratton not charging battery #1
ktm909
Goodrich Mi
Cub Cadet 2164
New to forum have a 2000 2164 that will not keep battery charged, battery is new,regulator changed. Can anyone tell me if they have seen electric clutch or
charging issues to look for that would keep from charging
thanks for any help
   / 2164 with briggs and stratton not charging battery #2
It could be helpful to know what specific engine model /type you have as well as the colors of the charging system wires. Briggs engines that use a separate regulator have a stator under the flywheel. The stator sends AC current to the regulator. Usually ~ 30 VAC That would be the next check as well as knowing that you have 12 Volts to the regulator- which would tell you that the power can at least get to the battery.
   / 2164 with briggs and stratton not charging battery #3
To do any meaningful trouble shooting without wasting money on unnecessary new parts and lots of your time you need a cheap multi meter.
Amazon has some for around $10. Local business likely have similar.
Check battery voltage before starting and after about 10 minutes of running and then tell us the numbers. Engine should be running wide open.
Tell me the spec's of your new battery. Often owners buy cheap batteries and there are not enough cranking amps for an older tractor making the battery seem like it is not charged.
Go to this web site and post the important numbers identifying your engine.
Riding Lawn Mower Engine Model Number Search
I dont see electric clutch being responsible for a dead battery if it is working properly otherwise.
Dave M7040
2014 John Deere 850K LGP Crawler Dozer (A59213)
2014 John Deere...
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2017 Toro Greensmaster 3150-Q Commercial Reel Mower (A56857)
2017 Toro...
(10) UNUSED SDLANCH 2.5CMX3M RATCHET STRAPS (A58375)
(10) UNUSED...
2018 PETERBILT 579( INOPERABLE) (A58214)
2018 PETERBILT...
