2210 rear work light connector behind seat
   / 2210 rear work light connector behind seat #1
Ray2210
Saskatoon, SK, Canada
John Deere 2210
I have a 2210 and have been contemplating how to best install and wire a rear work light and couple of front facing high mounted lights as well. When I purchased a rear light kit from JD I noted that the existing connector at the back of the tractor is not to be used. I also happen to be a long time Toyota guy and figured that the existing connector looks just like a Toyota connector....... and indeed it is. An early to mid 80's Toyota is a donor for the mating half of the JD connector. Other Japanese cars of that era might possibly be donors as well. I took one from under dash on an 82-85 Celica and another from the license plate light.
I have read that many have run myltiple lights from that factory rear light wire. It only looks about 18 ga to me so I will be sticking with one factory 37.5 Watt light on that curcuit and adding wiring for forward facing lights on the ROPS. I will control them with a light switch from a Gator that has a matching light sybmol to the rotary switch and matching style to the signal switch .
   / 2210 rear work light connector behind seat #2
<font color="green">Now if someone could just come up with a part number and source for a new connector that would be great.
Not sure I can come up with a used connector at the local auto salvage yard.
Mike</font>
   / 2210 rear work light connector behind seat #3
I run three 55W lights off of that connector (one rear light kit and two lights on the ROPS) and have never had a problem with the wiring. Seemed too light to me but so far so good. I do have the ROPS lights on a separate switch mounted on the LH side of the ROPS, but all power comes from the same lead.
2018 Ford F-350 (A55973)
2018 Ford F-350...
202482 (A54757)
202482 (A54757)
2021 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2003 International 9200I (A53317)
2003 International...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
