23 degree slope...bx 1800 vs b7510
   / 23 degree slope...bx 1800 vs b7510 #1
Dongerosa
Bronze Member
wellington ohio
7510 bota...RTV 900
I have a 23 degree slope that my BX 1800 Kubota climbed up without any problem. My question is, I just purchased a b7510, I think this has a higher center of gravity, will this incline present a problem?
   / 23 degree slope...bx 1800 vs b7510 #2
I had a CK20 which is about the same size/height as a B7510. No way would I travel across a 23 degree slope with that tractor. My sphincter alarm was on a hair trigger once I got past 18 degrees. Going up or down such a slope would not be an issue though.
This would be up and down!
   / 23 degree slope...bx 1800 vs b7510 #4
I climb 33 degrees on my BX1500 with MMM on and mow across 28 carefully. i think its a bit more stable with the low weight of the MMM. The climb is very near the traction limit. Have to use diff lock sometimes. I dont think 23 climb will present a problem with any tractor.
larry
   / 23 degree slope...bx 1800 vs b7510 #6
MY BX 1500s feel more stable on slopes than my BX 23 .
larry
378810 (A51572)
378810 (A51572)
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
