2320: Blew 2 Fuel Soleniods using Cruise Control
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #1
bill1369
Bronze Member
Massachusetts
JD 2320
Hi All,
I have blown 2 Fuel Solenoids (the second one literally exploded). The first time this happened, I was using the cruise control on my 2320 (which is a lever you pull up....not an electronic switch like in 3320, etc). I was driving along for about 15 minutes and then big puff of black smoke from under the hood. I investigated and noticed the wires on the Fuel Solenoid were fried. I replaced Fuel Solenoid (and the 40 Amp fuse near the alternator as that blew as well) and was back in service. Couple of weeks after this, I was using the tractor and needed cruiser control. Was driving around in cruise control for about 10 minutes and the same exact thing happened to the Fuel Soleniod....this time it literally blew up....and I blew the 40 Amp fuse again
I must have an electrical problem SOMEWHERE that only gets triggered when I use the cruise control.....but looking at JDParts, it looks like it is all mechanical.
Anyone have any ideas?? I have looked and looked at the machine and don't see anything shorting out.
BTW: I am out of warranty. Tractor is 3.5 years old
Thanks,
Bill
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #2
I just had my dash apart on mine. Yes, it is all mechanical, but there are some wiring harnesses near the lever and linkage. Probably a good idea to check around that area.
   / 2320: Blew 2 Fuel Soleniods using Cruise Control #3
I would check all your grounding cables for good contact to start with and look closely for any physical damage to the wiring.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
Utility Trailer (A52377)
Utility Trailer...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
