2320 Full Throttle Rear Snow Blower Harmonic Vibration
   / 2320 Full Throttle Rear Snow Blower Harmonic Vibration #1
MacTractor
New Brunswick
2008 JD 2320
I am wondering if there are any other 2320 owners with a rear blower that find at Full Throttle there is a bit of a harmonic whine around the HST filter.
I didn't notice it before, so I can't tell if it related to cold hydraulic fluid. I can make it stop by grabbing the left rear fender. Drop a couple hundred RPM's and it goes away. It also seems to go away under a good load, but I would assume this is do the the RPM drop as well.
Cheers,
   / 2320 Full Throttle Rear Snow Blower Harmonic Vibration #2
Mac Tractor
I don't have a snow blower, wish I did sometimes but we really don't get enough snow to justify one, but I have a harmonic when the tractor is cold (under -5 C)> It goes away once the hydraulic fluid is warmed up. Gets worse the colder it is.
Thanks for the Reply EdC,
Sounds like it is normal. It has been -15 the past few times I have been out there. I figured it must be cold fluid. I guess I should work the hydraulics a bit to warm it up before putting it to 3K. I normally wait for the engine to warm but not the Hydro.
   / 2320 Full Throttle Rear Snow Blower Harmonic Vibration #4
All I do is cycle the hydraulics, slowly at first, for the first few minutes of warm up. Seems to work. I would be interested in knowing if it works in colder temps like what you have. One of these days I really want to move back to Montana and it does get a might colder there than it does here in eastern Washington..
84in Grapple Rake Loader Attachment (A56857)
84in Grapple Rake...
Michigan L90 (A55272)
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
We Don't Call 911 Metal Sign (A57454)
We Don't Call 911...
Ford Dully Bed (A57453)
Ford Dully Bed...
