2320 PTO shaft for front Hitch- Snowblower
   / 2320 PTO shaft for front Hitch- Snowblower #1
Sven_SITE
JD 2320
So i was one step closer to getting my new 47" Snowblower working the last snowstorm until i could NOT get the PTO drive shaft to slip onto the PTO under the tractor for the front hitch/drive. Any ideas? It almost seems as though there is a roller ball catch that needs to push in to engage on the pto but its not? could something be siezed? Am i not alligning something correctly?
   / 2320 PTO shaft for front Hitch- Snowblower #2
There is a collar on the driveshaft that needs to be pulled back to disengage the lock-balls. After sliding it on the stub shaft, release the collar and slide back and forth till the balls engage in the groove.
THANKS!! I will try that tonight!
   / 2320 PTO shaft for front Hitch- Snowblower #4
Also try shifting the PTO lever to the rear PTO position which will put the mid-PTO in "neutral" allowing it to turn freely and easily aligning the splines. If the shaft is dry a little WD 40 helps too.
2022 CATERPILLAR 303CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A54607)
2016 INTERNATIONAL...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
205028 (A52706)
205028 (A52706)
