2320 vs. 1025r How much bigger is the 2320?
   / 2320 vs. 1025r How much bigger is the 2320? #1
holzboat
Bronze Member
Long Island, NY
JD 4110, JD X595, JD 4100
I can't find much online for the 2320.
The 2320 has a 63" wheelbase and weighs 1660lbs. That is all the dimensions I can find.
The 1025r has a 57.1 wheelbase and weighs 1444 lbs. It's 47.2" wide, 102.6" long with hitch and 41.5 inches high at the hood.
How much bigger is the 2320. I'd like to be able to clear snow from a 48" sidewalk as well as as bunch of driveways and a few small parking lots. The 1023e/1025r is pretty tight for the sidewalks and I'm wondering if the 2320 is too large to fit.
Anyone have a photo of the two side by side?
Thanks,
Roger
   / 2320 vs. 1025r How much bigger is the 2320? #3
I owned a 2320 in the past, I currently have a 1026R. For what you say your planned uses are, I would recommend the 1025R.
My 1026R works better in tight spaces & is faster than the 2320 when plowing snow in open areas.
Thanks for the replies. I've been to Deere.com and TractorData but neither one lists dimensions for the 2320 other than weight and wheelbase. I've read through dozens of threads about 2320's but still no actual dimensions.
Does anyone know how wide and long a 2320 is?
Can't open this one- http://www.****************.com/foru...0-ones-me.html Wonder if it's got the info I'm looking for?
   / 2320 vs. 1025r How much bigger is the 2320? #6
I found this pretty easily online just now-
This is for the 2320
hide Technical Specifications:
Length 9.1
Width 46.8 / 1188
Height 89 / 2261
Wheelbase 63 / 1600
Turning Radius 2
Ground Clearance 12.5 / 318.4
Front Tread Width 31.1 / 790
Length (ft/ft) 9
Length (ft/in) 1
Dry Weight 1660 / 753
Fuel Capacity 6.1 / 23
   / 2320 vs. 1025r How much bigger is the 2320? #7
And this is easy to find on JD's site-
OMLVU16740_E9
Dimensions
NOTE: Machine equipped with standard tires.
Wheelbase 1600 mm (63 in.)
Overall Length with 3-point Hitch 2774 mm (109.2 in.)
Overall Width (Minimum) 1188 mm (46.8 in.)
Tread Width @ Centerline (Minimum)
Front (Only Wide Position Recommended) 923 mm (36.3 in.)
Rear (Only Wide Position Recommended) 919 mm (36.2 in.)
Height From Ground
To Top of Hood 1208 mm (48 in.)
To Top of ROPS 2261 mm (89 in.)
Ground Clearance
Front Axle 320 mm (13 in.)
Rear Axle 260 mm (10.2 in.)
Turning Radius
With Brakes 2.0 m (6.7 ft.)
Without Brakes 2.3 m (7.7 ft.)
Thanks! I've been searching google but I guess I've looked everywhere but the owners manual. Seemed odd that TractorData and Deer.com had the dimensions posted for almost every other model but not this one.
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
